A cracked manifold will mean exhaust gases will escape where they are not supposed to which will affect acceleration so this will affect mpg i also know that a faulty EGR valve can cause poor mpg i have had this problem but along with a faulty coil pack as wellhi
How do cracked exhaust manifold affect MPG???
my 2.2 vectra b do 16 mpg roundtown verrrry bad , I have changed the (air filter, spark plugs, O2 sensor and no check engine light), but have a cracked exhaust manifold..any advise will be appreciated
Your 02 sensor will pick up improper readings with a cracked manifold once you have replaced the manifold then you see how it affects 02 sensorBut what do you say about the effect on the O2 sensor..
