I am feeling deflated after going through the ordeal of swapping my dud GM Holden/Vauxhall/Opel Zafira Engine over with a good second hand engineand went to check the operation of it and it just does not seem to run. It turns over fine and seems to have good compression.
There are no fault codes present according to mechanic who came around with a scanner, with the exception of the Air con since the radiator and condenser is still out and hence disconnected I just want to start is and make sure it is all okay before putting the front back together.
It seems that it will eventually start after cranking for a while and holding full throttle. It will run at 500rpm at full throttle but if the throttle is closed, it will straight away stop the engine. The spark plugs are new and I took out and they were carbon black and had wet (fuel) on them. I was thinking that something is stopping the spark from working properly.
The old engine ran okay except it was noisy (conrod bearing) and I am using the new engine (only carried over temp sensor, crank angle sensor and I thing an oil pressure sensor. I am using the original electric loom and coil assembly. I was thinking that there is a problem with the coil connector or something but it seems to look okay. Does the engine know there is no coolant and refuses to spark properly? How would the engine know if there is no coolant and if it it did, what would it do? Can anyone please help? I am stumped.
