vocky said:a lesson in there somewhere notsure.gif
check your oil level, it only needs to drop below the minimum to cause the con rod failure seen above
Do you mean below the dipstick minimum oil level or below when the 'check oil level' warning light comes on? notsure.gif dunno..
