Had a chat with Mark Watts this morning about this weekends events. He's fairly confident that the engine is okay. He mentioned that if the engine was damaged in any way there would be tell tell signs by now and that there are cars running Stage 1 conversions at 220bhp with no charge cooler pre rads and they are fine. The fact that I don't drive the car really hard or use it on the track should be a bit of a saviour.
I did notice the pump kicking in this morning when I turned the keys whilst in the garage. The pump is quite audible when you're in the garage. Can't say that i've EVER noticed this sound before in almost 2 years?? I turn the ignition on and there is now a combination of the fuel pump and the water pump, then you just hear the wurring of the water pump.
I drove to work this morning and it was -2.5'C outside. Within 5 minutes the the engine temp was just over 80'C. This is where it stayed for the rest of the journey to work. I gave it the beans in a few places and the wheels were spinning up throughout 2nd gear. Before this, the car has felt sluggish under acceleration and the temp shoots up over 90`C when under load, but this morning it topped out at 85'C.
Same story on the way home from work tonight. Its very much stop/start coming home from work and sat in traffic. The cooling fan is always on by the time that I pull up on the drive. Outside temp was showing 8`C and again, the water temp was showing 85`C. Got home and no cooling fan running.
I just need to monitor the fuel consumption now too just to see if this gets any better. Mark said that with the extra heat the car would have run richer.
Fingers crossed!!
**EDIT**
I forgot to mention, i've been driving for well over 12 months with the hot blowers on to keep the engine temp down when driving in town.
