Drakey
Hi again to all,
still having problems with loss of power from my vectra.
Engine and fuel flush carried out along with injector cleaner, EGR valve replaced then blanked, engine tested for air holes, plugs and pack swapped and tested, Tech2, Tech2 and more Tech2, Lambda sensor fault, again after having them both changed, fast running out of ideas.
Had a quick coolant level and break light fault flash up but both were fine, now seriously thinking of changing the ECU.
Does anyone know the best place to aquire one, last hope before ordering a new engine!!!!
