Made a start in stripping the interior, pulled all un needed wires from the rear loom to the front ready for trimming. Started drilling out the spot welds for the original seat mounts but soon got bored so got the heat gun and scraper out and whipped up all the tar sound deadening.
Bagged it all up and got 15.3kg's worth with a tiny bit left under the dash so I reckon 15.5kg total which of a decent weight saving.
I'd ordered some 3" bass ports to modify as brake duct feeds
Trimmed the bumper trim down and cut the tabs off the ports and siliconed them in
Trimmed the spot light brackets off and removed the factory brake duct feeds
And re fitted
Fitted and balanced up the dry track tyres to my other pro race 1.2's
Marked up which brackets I wanted to trim off the radiator which aren't used
So that I could fit my corsa's old forge intercooler
Fits nicely behind the bumper bar, I'll trim a bit more out of the bar to add flow
Bumper will have a couple more holes added where the Velcro tape currently is
I've decided to go for a intercooler because on track the standard charge cooler doesn't keep the intake temps down low enough and for a 40 minute race which I will be doing I will struggle as i've hit the map cut before and it saps about 50bhp once the intake temps get to around 63 degrees C. With the intercooler it will never get that high. I will be modding the inlet soon to change it to run air to air.
