jimbob-80 said:
This seems like an interesting project. Just a few questions if you don't mind mate.
1) When bolting on the supercharger kit, what other components need changing? i.e. ECU, Brakes, Cams, engine block, Suspension ect. With regards to the engine though, i would love to here what you intend to keep standard.
In addition to the cost of the supercharger (which has a modified pulley on it) and the inlet manifold (which houses the chargecooler heat exchanger) there are about £1500 worth of additional comonents (plus labour) required to carry out the conversion (including injectors, pulley, pump, charge cooler pre-rad, pipework, airbox, fuelling ECU, spacer plate, additional guide pulley and bracket, spacers for aircon, etc etc) although the engine remains as it left the factory.
The car already has Bilstein B8 dampers and Eibach Springs fitted. Also uprated front bushes and rear anti roll bar. Brakes are 16G uprated fronts and fast road pads, rears are uprated discs and pads too. It has also got a lightweight flywheel and sports clutch. I've concentrated on getting the brakes and handling done first before increasing the performance.
jimbob-80 said:
2) How long will this conversion take? (If it is not done already!) and what will be the final bill be. (If you don't mind me asking!)
From start to finish should take about 7 days to do but I'm having to fit it in and around work plus develop components on the way!! Need a different inlet set up and the top hose has got to be re-routed using something yet to be designed. Final cost will be released when I know what it is.
jimbob-80 said:
3) Finally, why did you choose to supercharge a vauxhall? I used to have a scooby turbo and always wondered what it would have been like with a supercharger! Did you consider any other car?
Looks like your astra could be truly amazing, I hope it turns out like you want!
We chose to supercharge the engine because it was a further development of the GM 2.0 supercharged engine used in the USA plus we have installed many into VX220.
Since I work for Courtenay Sport running a Vauxhall seems to be the right way to go!!
vocky said:
it has a thicker head gasket to lower compression
ecu has a piggy-back added
brakes would need to be 308mm minimum
Correct, although it is a laser cut spacer plate (decompression plate) rather than a thicker head gasket as the spacer plate is run with two head gaskets too. The car has been running on lowered compression for the last six months as I've already done that bit and have been gathering the other required components.
The aftermarket ecu is designed to control the on boost fuelling and is fully mappable
and yes the discs have been upgraded from standard to uprated 308mm with uprated pads.
