car is 7 years old though Daz
timing chain snapped on a 7yr old z22se i doubt anyone would think twice about it
They do a lot of M32 repairs. They have about 8 sat on the self already reconditioned ready to be fitted.Just been looking on ebay and seen mister gearbox selling m32's on there .
That's the problem. VX are fitting new boxes that have the same problem as the one which has just failed. VX don't repair them and replace the bearings, they just swap the whole box out.I appreciate that mike. however a local m8 of mine had a new gearbox fitted under warranty on his 6 year old vxr last year. and guess what, it f**ked again after 10k.
It's totally pot luck Mike. I thought mine was OK right upto this week, when actually looking back, it's probably been on it's way out for over a year now.well no way i gonna buy a 2nd hand vxr when they is 10 yrs old
DMF only really fails on the diesel engines. You don't really see any instances of it having problems on the petrol models. They checked my clutch and DMF yesterday while the box was off, and there was nothing wrong with them.so DMF as well as bearing failure
I use the thicker GM oil in mine, the original factory oil is like water
Erm, they didn't actually say what they used. I'll contact them tomorrow and see if I can find out.What gear oil did they use Matt?
s**t! How common are faults on the F23? I've not seen many threads about them having issues. Are you running with more oil in the box as per the TIS article?irony matt is that i have sneaky feeling my gbox is starting to play up
smooth gear change is getting clunky, been like this since sitting in rush hour last year
I have loosened up my gaitor to see if it helps as it was brand new and very rigid
I think changing the oil on mine got me an extra 12 months out of it TBH. I also spend a lot of time over the last 18 months in stop / start traffic going to and from work. I'm glad I'm back on shift now, as there is no traffic at 7am or 7pmthat's my next job
changing the gearbox oil, but i think all that stop start traffic has worn the box so i am not expecting much
there is a slight rattle from the linkage on the box when i change gear, but i know that occurs from wear n tear
