Hi all is their anyone on here close to stoke on trent that has a tech 2 or opcom that would come and have a listen at my astra coupe and plug her in she is poorly please help
Windows 7 iv tried running it normal and then running it with no driver signature but can i hell find the drivers. i can open the software and select my car but thats it
I know it's been mentioned to me before that all you needed to do was turn off driver singing. However, I found a guy on the Astra Owners Forum who logged into my PC and basically sorted the actual software in the OpCom so that it would just be recognised as a USB device and it would load easily. I've had it running on my Win 7 PC and I use it on my Win 8.1 laptop with no problems. I recently managed to program a new key with it after soldering on a new transponder.
This is the guy (hope no one objects) his name is Mark 152 on the forum. You'll have to join and then PM him, he was helpful but obviously he doesn't leave the software that he use to reprogram the interface on your PC as it's a custom software.
