I'v just bought my car so first job of 2014 is to replace the chain's are after market kits any good or not.
obviously I know the gm kit's are probably the best option but I could do with saving a few quid as buying the car ate all my dosh.
gm main chain then FAI balancer chain and same the z22se shop is best for the latest spec parts and prices
with ebay you could be getting old stock
the fai are both tried and tested they get my vote and ive fitted both gm and fai for people with no complaints
