Replaced battery on my zafira after advised to by rac. Car started but really misfires esp under load then cut out and wouldn't start just turns over. I kept trying then realised I couldn't hear the lift pump from the back like you usually can when you turn key to the position before starting. I took key out put it back in then I heard pump and it did start. Then cut out again round the corner and wouldn't start at all.
So my question is should that lift pump go every time I turn key right back to off and try to start or does it not if you have been trying to start a few times.
I know z22yh has the hp pump and that has been replaced a couple of years ago
But no fuel pressure codes are showing only codes are misfire for each cylinder still.
