Short update:
Due to massive knock that I think should not be there (phantomknock) I adjusted the KS with a thin gasket between the KS and the block. I also upgraded my sparkplugs to NGK ITR7IX-11 Iridiums gapped to .030 (0,7mm). This seemed to work good as normal knock was still detected but way less false knock. Timing was were it should be (16/17 instead of 13/14 degrees).
Oil leak is finaly solved and the car is 99% mapped for 0.5 bar boost and pushing out 240 bhp / 309Nm (227lbs).
Great fun drivin' it around now. Instant boost so great fun on the twisty B-roads.
Next few weeks I have some time off so will start with the 0.6 / 0.7 / 0.8 bar maps. Should see 260bhp (I hope so..)
IAT's are still abit high at 55-65C when pushing it with powerruns and sitting still to map (heatsoak). When 70ish C and then running the car again at highway speeds the temp only drops back to 58-60C IAT.
So I started with the airflow. Ordered side vents from Eltech to replace the N/A mesh and create more inflow. Used some alu bolts to space the diffuser 1" from the clam:
The Dutch trackers seem to have good cooling results by doing this. Not directly to do with the IAT's but a cooler/better vented enginebay seems a good thing on a mid engined car.
