Zafira A Z22SE
DreiVier
Hey Guys,
There are tons of informations in this forum. But I still need some infos.
I want to do some small things (for now) with my Z22SE (got the OK from my better half):
1. Vectra C inlet pipe:
Does anybody know if it fits on the Zafira A?
Part numbers:
Main Pipe 9177099
Adaptor to Airbox 9177104
2. derestricting the air box (K&N filter akready inside which gave a noticable difference):
Seems to be easy.
3. ported throttle body
Don't have the tools to do that, anybody could help perhaps? :)
4. precat removal
Seems to be easy also.
5. exhaust manifold
The one from the Z20net should fit,
so that is fine.
Thanks a ton!!
I don't think the Vectra C pipe is available anymore. You could try the Astra VXR pipe. That "should" fit, as it fits the Astra.
DreiVier
Jepp. Found another one from the Astra H CDTI I think. Somebody mentioned it in the vectra c pipe thread. That's already been done :)
Airbox is already derestricted also.
I am sure it is.... I only brought mine about 6 months ago?
Might be remaining stock, but I'm sure I read on here and other places they were no longer available?
I'll check next week at the dealers to see if they can still get them.
I heard the same on other forums also, most went for the VXR one now if have seen the odd one on eBay a ridiculous but it now price.
DreiVier
Just did some things on the car in the last weeks :) New rocker cover, ported T/B thanks too @evocarlos , cleaned the engine, new oil etc etc :D
MOT passed without any problem :D
DreiVier
Cool, so it sounds normal :):D
Peanut Butter? No way! The only place for peanut butter is on my bread :D:D:p
Thanks for the vids Carl! Time to get my heat gun out.
Only things left at the moment, flexi pipe and pre cat removal.
DreiVier
Perhaps a little bit ;)
Got a call from my girl today, aircon is not working :mad::confused:
It's around 25-30 degrees outside so it has to work:eek:
