Thank you! My mechanic wasn't planning on removing the crankshaft tho, because apparently you can hone and replace the rings without doing that?
Also, I need a hone device / tool for the cylinders, but I'm not sure what size I need. Does anyone happen to know?
And do you happen to know what gaskets and seals there are? Headgasket, and on the carter, is that also a seal?
Cheers
Cheers
