brand new 2018 delivered, it's been a while since I have fitted them to a z22se engine.
Most people buy the Dbilas springs and they use OEM caps, plus the last few sets of Supertech kits I've fitted were on new B207 engines which have the cast rockers.
Obviously you can grind the roller rockers for clearance, but it was easier to swap them for the cast version
Just be careful to double check the clearance, rotate the engine a couple of times. Once it's been started remove the rocker cover and double check there has been no contact between the rocker and supertech valve cap.
