For Sale z22se engine 74k
figo126
time to sell my 74k original engine for my coupe , this car was bought with 16 bent valves , june 2015, had the head re-built , 16 new valves , 16 new cam-followers, new guides ,elring head gasket , new elring head bolts , port and polished exhaust ports , skimmed , pressure tested, new genuine gm big-end bearings ,while engine was out did the balance shaft delete ,this engine has only covered 2k miles since getting the car on the road ,has genuine gm balance shaft chains + genuine gm timing chains , I have about £1000 in this engine thinking I were going to keep the car standard but after joining this forum , and looking at everyones projects ,I'm going the b207r turbo-ed route so decided to let her go (need room ) so any decent offer will be excepted, the engine is removed and ready to go , you can have a look at my project page on here to see the work ive done , the hydro-dipped rocker does not go with the engine sorry, any questions don't hesitate just send a text or ring on 07917546633, cheers ian ,,,,,,,
