What is this part ?
sinisa97
I've been trying to find out what this part is on an vectra b 2.2 with auto box. Can anyone help identify the part?
The Vectra B's have a mechanical power steering pump, driven by the inlet camshaft which has a hex drive on the end.
(The Astra G/Zafira A & VX220 had different inlet camshafts as they had electric PSP's.)
corsaZ22se
It's the power steering pump as Kevin says.
There is a blanking plate on the other models to cover the end of the cam shaft.
All the standard GM cams I have seen have been the same with the hex drive in the end only the performance cams sometimes don't have the drive unless you order the new cams with it.
sinisa97
So the mechanical power steering pump can be taken off and a blanking plate installed and I can install this 2.2 out of vectra b into Astra g Coupe? If I decide to do it, is there anything to look after, or will the swap require any modification beside the pump?
corsaZ22se
Yes you can unbolt the pump then bolt the cover plate back on. Be sure the seal is in good order.
Engines are the same on all Z22SE's just the ECU software that's different so keep the Astra ECU and it will be fine.
Es posible, pero ¿por qué? ¿Qué es lo que intentas conseguir que no se puede hacer con las piezas estándar adecuadas?
Hola gracias por contestar, tengo dos Vectra b.
Vectra b y22dtr y Vectra b z22se.
mi caso es que la dirección asistida del Vectra diesel (bomba eléctrica) es mucho más suave que el de gasolina (bomba mecánica)
Por eso tenía curiosidad si se podía poner al Z22SE la bomba eléctrica del Astra g Z22SE.
Un saludo...😊
Mis dos Vectras.
