water temperature sensor change
Engine / Transmission water temperature sensor change
water temperature sensor change (version 1.0) - water temperature sensor change on a Z22SE
heres how to change the water temp sensor on the z22se
ive changed mine for the sake of it but if you ever do need to change it heres how :)
the part
you can get it from here i did :)
http://z22se.co.uk/shop/service-parts/water-temperature-sensor
parts required for the job
water just incase you lost alot in the process
19mm spanner or ratchet spanner if you have one that will fit the gap
new sensor and about 15 mins
here is the...
