Mine has corroded at both ends where its fixed to the corrugated solid section, so it slides back on acceleration and slides forward until it hits the down pipe when stopping. Now I've seen whats underneath I don't really see the need for the wire braided cover.
Yep, it was p**sing me right off. I'd noticed it when I bought the car, and it's taken almost a year to get to the bottom of it.......and such an easy fix as well.
