whats the best way of checkin the arb bushes and drop links for wear? does it need to be on the ground or in the air, i get a rattle from the front right when i gove over speed bumps, but comes and goes?? notsure.gif
I didn't realise that there was play in my drop links until it was up on the ramp for the MOT which was when Daz found the problem. I would say that you need the car off the ground so that there is no loading on the suspension.
