HoldenVectraC
Hi I'm Daniel, I'm new around here but have searched a bit and still can't find the answers to my issue.
So I recently bought a Vectra C with a z22se engine and manual transmission, first started having an issue with the check engine light and error code P0601 which caused the engine to cut out, decided to replace the ECU and also the CIM and key / chip, which the parts came from a 2003 auto vectra c.
Now im having an issue with the central locking doesn't work from either new or old key, I also swapped the ignition barrels between CIM so I could use my old key.
Also now the engine does not start at all, coming up with padlock regardless of which chip I use with my key.
Check engine light shows and gives code U2106 meaning loss of communication with transmission control system probably because the parts are from an auto, but shouldn't the car still run regardless of this?
Any help is appreciated, thanks in advance.
