ok so i fitted the vectra c intake today , it dosnt seem to line up properly with the air box it sits in front of the bottom pipe to the airbox but slightly at a angle is this normal?
just twist the pipe at air box end. I find the real problem is fitting the connector to the vec c pipe as the connector just sits inside it (not ideal)
