justathome
Hi everyone,
I have a new opcom V2.
Freshly installed win7 laptop no other software except opcom.
Software installed, and installed the drivers from the drivers folder.
Ran test interface and updated to V1.39. and now tests all ok.
When running diagnostics to the car ( vectra C 2005 ) all I get is a click and 'there is no communication with the ECM'
I'm stuck, any advice. I have an emissions (engine)warning light on and trying to diagnose.
EDIT
Further testing by scanning each individual ECU came up with the following results.
Any help would be appreciated.
These come up as 'SWCAN' scans..
OP-COM 090821d - PC based diagnostic tool
Please add your workshop
name in the settings window
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|BCM (Body Control Module)
Read Info...
Identifier: 0x0208
VIN: W0L0ZCF6841119024
Part Number:13168783
Software version number: C12C93 08041404
Hardware key number: ÿÿÿÿÿÿÿÿÿÿ
System description: TEMIC04
Variant programming : 0x20202020202020303030363638343839
Alpha code: EJ
Manufacturing date: 000400050008
Code Index and version:
Total number of fault codes: 3
B3057 - Security Code Not Programmed
(00) - Intermittent
B0967 - Park Pilot Switch Circuit Open or High Voltage
(05) - Present
B3916 - No Communication With Alarm Siren
(0F) - Not present
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|Instrument
Read Info...
Identifier: 0x0102
Part Number:13165955
Software version number: 8.39 16/03
Hardware key number: 0000000000
System description: VDO 0400
Alpha code: MB
Manufacturing date: 040510
Code Index and version: 001 05
Total number of fault codes: 1
U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
(7F) - Not present
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|PAS (Park Pilot)
Read Info...
Identifier: 0x0101
Hardware number:50
System name: PAS
Part Number:13181070
Software version number: 0000002D
Programming Date: 20041904
System description: BOSCH0400
Alpha code:
Code Index and version: 009 01
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
U2107 - Invalid Data from BCM (Body Control Module)
(71) - Present
B0952 - Loudspeaker Circuit Open or Low Voltage
(06) - Present
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|SDM (Airbag)
Read Info...
Identifier: 0x0101
Part Number:13170590
Software version number: 0C0C3303
Variant programming : 0x41533035393053303330383238384720
Alpha code: DW
U2139 - Invalid Data from CIM (Steering Column Module)
(00) - Not present
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Infotainment System|TID (Triple Info Display)
Read Info...
Identifier: 0x0306
Hardware number:13190895
Part Number:13190970
Software version number: 08.08.17.00
Alpha code: WZ
Manufacturing date: 040429
Code Index and version: 002 02
U2103 - No Communication with CAN-Bus (Mid Speed)
(00) - Not present
These are the one that won't comunicate (time out and no communication errors)
and come up as'HSCAN' scans
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Engine|Z 22 YH
No stored codes!
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Chassis|ABS/TC/ESP
No stored codes!
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|Immobilizer
No stored codes!
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Body|CIM (Steering Column Module)
No stored codes!
As you can see alot of errors relating to CIM, would these be related to my inability to scan both it and engine/abs ecu's?
Any advice would be appreciated...
Justin
EDIT
Read Info...
Identifier: 0x0208
Alpha code: EJ
(00) - Intermittent
(05) - Present
(0F) - Not present
Read Info...
Identifier: 0x0102
Alpha code: MB
(7F) - Not present
Read Info...
Identifier: 0x0101
Hardware number:50
System name: PAS
Alpha code:
(00) - Not present
(71) - Present
(06) - Present
Read Info...
Identifier: 0x0101
Alpha code: DW
(00) - Not present
Read Info...
Identifier: 0x0306
Alpha code: WZ
(00) - Not present
No stored codes!
No stored codes!
No stored codes!
No stored codes!
Justin
