Hi my Vectra 2.2 Sri failed its test on emissions and when the mot guy revved the engine to improve the readings it smoked heavily with grey/white smoke
The head has been rebuilt and new valve guides used after 1 valve had burnt out
Head was skimmed and a genuine Vauxhall gasket and new bolts used
When the head was off the bores looked fine and no scoring evident
Previous to this the car had been using oil through burning it not leaking
I now have the dilemma of what to do with the car?
Reading through most posts worn rings are possible? (98000mls recorded now)
I ran the engine with an oil flush thinking that it may be rings sticking? But this hasn't made any difference? Now I have drained and changed the oil again
There are suggestions of spraying carb cleaner down the plug holes to free the rings? This might be worth a try?
The engine fires and ticks over on its own fine it's just when revved it smokes grey/white and smells oily?
Someone mentioned that the cat may be oiled up causing a blockage?
The Vectra has been garaged up from time to time and always ran lumpy when the engine was worked
Any pointers as to what's happening would be appreciated?
I can get a new cat for £60ish and would consider this before stripping the engine out?
