vectra b speedo not working
hey guys im stumped my moms vectra b had a funny turn in the wet the other day and all the speedo went down
fuel/temp/revs/speed
but then came back for a week it now off again and i cant find the problem fuses all look intact
any pointers or has anyone suffered the same ?
#10
if all of you gauges have gone at once i would suspect it to be a power to the dash fault or the voltage regulator on the dash its self. this is part of the dails circuit board. you may need a new/second hand set. only around £30 from a breakers.
cool will have a look monday for a new set
but the went off then come back on now there gone again
what about multi timer ?
multi timer ?
MikeS
multi timer is connected to the instrument panel lighting however unsure about function of the panel itself
I be looking at buying a 2nd hand instrument panel and dropping it in if you are unsure ow to check voltages
mfd is working
speedo - no
rev counter - no
mileage display - no
water temp - no
fuel gauge - no
dash illumination - yes
fuel light - yes
P brake - yes
engine check lights - yes
also looks like a mouse has been in the engine bay but no sign of damage to wiring
i can check the wires with a multy meter but need to know there function from a wiring diagram to make sure im testing the right ones
the clocks started working again the other day and is still working now
mom had complained about a light flashing on the dash had me mate plug in op com and it had p0110 code was cleared i,ll see if it comes back
i think mom had gone flat out thru a big puddle in the rain we had last month it must be all dry now tho lol
soon find out when its wet again
