dewismotorsport
i have a astra g z22se and have a mapped supercharger Ecu from a vectra b. Now I know the Vectra uses a series of relays to run the fan side of things and the Astra a cooling module.
Would it be possible to convert the Astra to run the vectra's relay set up and ditch the cooling module?
I've asked courtenay sport if they can swap the maps over from Ecu to Ecu but they said no. So want £200 for base map then £95 an hour for mapping. They reckon it could be done within the hour. How long did it take on others cars?
I have Omex 600 which I'm tempted to make a loom for and map that with my friend but is more of an expense than a retro fit of a realy set up.
