it is just a fat bulb bottom of the instrument panel
very important
when levering out the instrument panel make sure you correctly unplug the TID/ MID as the connector on the back are fragile and once broken u need a new loom cos it pops out very easily
1. remove steering column shroud
2. remove heater vents using this screwdriver / knife
3. remove headlight switch box using thin screwdriver
4. undo bolts behind the above 2 things
5. remove trim surround for dash
6. remove instrument panel surround
7, undo the screws for insturment panel
8. carefully unplug the TID connection on back
9. slide out instrument panel
tips - u might want to remove the stalks when u screw everything back in
if u need any spare bits contact burt150 as he had most of my stuff
