Further to Vocky's reply, you will not only require to find the same type of gearbox, but also one with the same transmission code, as various models had different transmission codes, which probably meant different gearing.
The automatic transmission fitted to Vauxhall/Opel Vectra B with Z22SE engines is:
Transmission Type*.......... AF22
Transmission Code*.......... TD
Control Unit Code.............. AJ
*The transmission type/code is marked on the identification plate which is attached to the top of the transmission unit.
Opel Vectra B with Z22SE(L61) - Transmission, assy.. with converter, (ident td) - Opel part # 0701209 (GM part # 9126260)
Note for automatic transmission refitting:
1. New torque converter-to-driveplate bolts required
2. New fluid cooler sealing rings required
3. New driveshaft oil seals required
Hope that info may help.
