Vectra b 2.2 Z22SE automatic transmission module
win.walid
Hello every one:)
I feel very very nervous :banghead::banghead::banghead:, today I removed the transmission module for checking because I have u2108 and p0700 faults but after reconnecting, the sport mode dash light disappeared at all, and the transmission is on emergency mode all the time!!!!!!!, could any one tell me what happened there please.:cry::cry::cry::cry:
Best regards
Probably not - it will require a TCU with the same production identity two letter code (which is usually on a label on the unit itself) and it would then need programming/pairing with the main ECU.:)
win.walid
Hi
If I replace the TCU with a same one (part number...etc), does it still need programming??? or just if I replace by one with a different part number ??
