Ande89
Bonjour fellow z22se owners
I have a problem...
Started last monday i started my veccy and stalled instantly... started again and manually kept my revs up and started driving... and whilst i was driving it got rougher and rougher so i took it strait to pk automotive to get a diagnostic to which i was told because no lights are coming up theres no point but he had a quick gander round... and told me that it would be my crankshaft vaccum valve ( the plastic disc that has a feed pipe into the rocker cover ) so i had that replaced and no joy...
So i disconnected my maf sensor instantly it actually improved... it didnt stall but it had idle bounce and drove decently... so i drove it to a friend who looked over it... he cleaned up the maf, he used carb spray on the throttle body, took off the fuel tank vacuum valve and cleaned it out, and it seemed it did the job... now its happened all over again.
As i was told because its not the direct and the difference when the maf is disconnected it wouldnt be my fuel pump... does anyone have any ideas????
I have a problem...
