Hi,
I today fought with the standard air-intake pipe off my astra mk4 2.2 Sri, took me ages to get it out! I removed the airbox and took out the bottom and top pipes to de-restrict and then put in the veccy 2 air intake pipe which has the bigger scoop, again, this took absolutely ages for me and had to cut some of the pipe going into the intake pipe off.
What I want to ask is there some sort of flexible piping you can get to connect the air-intake to the air box as mine isn't perfectly connected (little gaps going to the air-intake veccy pipe from the airbox pipe).
Any advice is much appreciated.
Thanks
Thanks
