Vauxhall Vectra 2.2i Direct SRi 5dr Hatchback
Mark Dj
Technical specification
Emissions
CO2 (g/km) 180
Standard Euro Emissions EURO 4
Engine and Drive Train
Camshaft DOHC
Catalytic Convertor True
CC 2198
Compression Ratio 12.0:1
Cylinder Layout IN-LINE
Cylinders 4
Engine Layout FRONT TRANSVERSE
Fuel Delivery DIRECT INJECTION
Gears 6 SPEED
Number of Valves 16
Transmission MANUAL
Fuel Consumption
EC Combined (mpg) 37.7
EC Directive 1999/100/EC Applies True
EC Extra Urban (mpg) 47.9
EC Urban (mpg) 27.4
General
Based On ID N
Coin Description i Direct
Coin Series SRi
Insurance Group 1 11
Insurance Group 2 E
Man Corrosion Perforation Guarantee - Years 6
Manufacturers Paintwork Guarantee - Years 1
NCAP Front/Side Impact 9
NCAP Pedestrian 9
Safety Concerns? False
Special Edition False
Special Order False
Standard manufacturers warranty - Mileage 60000
Standard manufacturers warranty - Years 3
Performance
0 to 60 mph (secs) False
0 to 62 mph (secs) 9.7
Engine Power - BHP 155
Engine Power - KW 114
Engine Power - PS True
Engine Power - RPM 5600
Engine Torque - LBS.FT 162
Engine Torque - MKG 22.4
Engine Torque - NM 220
Engine Torque - RPM 3800
Top Speed 134
Tyres
Tyre Size Front 215/50 R17
Tyre Size Rear 215/50 R17
Vehicle Dimensions
Height 1460
Height (including roof rails) N
Length 4611
Wheelbase 2700
Width 1798
Width (including mirrors) 2036
Weight and Capacities
Fuel Tank Capacity (Litres) 61
Luggage Capacity (Seats Down) 1050
Luggage Capacity (Seats Up) 500
No. of Seats 5
Mark Dj
Engine
Bore & Stroke: 86.0mm x 94.6mm
Displacement: 2198cc
Compression Ratio: 10.0:1
Fuel System: Sequential mulitpoint fuel injection.
Engine Block: 2.2 Litre 16V ECOTEC 4 Cylinder
Maximum Power: 108kW@5800rpm
Max Torque: 203Nm@4000rpm
Cylinders: 4
Valves: 4 per cylinder
Transmission: 5 speed manual
Gear Ratios
First: 3.58:1
Second: 2.02:1
Third: 1.35:1
Fourth: 0.98:1
Fifth: 0.81:1
Reverse: -
Final: 3.95:1
Suspension
Front : Independent. MacPherson struts. Lightweight aluminium uprights & control arms. Mounted on subframe. Coil springs. Gas pressure dampers. Stabiliser bar.
Rear : Independent. Four-link: three transverse & one longitudinal arm. Coil springs. Gas pressure dampers. Stabiliser bar.
Brakes
System: ABS
Front : Ventilated discs
Rear: Discs
Wheels & Tyres
Wheels: 6.5 x 16 Alloy Wheels
Tyres : 215/55 R16 93H
Steering
Steering: Rack and pinion, power assisted.
Towing
Towing Capacity: 1500kg(with brakes) 715kg(without brakes)
Dimensions
Length (mm) : 4596mm
Height (mm) : 1460mm
Width (mm) : 1798mm
Weight (kg) : 1406kg(kerb)
General
Fuel Tank Capacity : 61 Litres
simon
Hi there,
new here, pick my sri 2.2 xp nav up on monday.
My old sri has covered 232000 miles (all mine) so had to buy another.
simon
Hi Simon, welcome to the site. Why not pop a post in the Introduction Section, for a nice warm welcome.
