daiflu
Hi guys, just wanted to run something by you.
I have the 2.4 manifold and need a vacuum source for a remotely mounted MAP sensor.
Unfortunately there aren't the unused sources like the 2.2 manifold.
I have tapped into the purge valve to manifold line, as it is closest to where I will mount the sensor. Is this the best place for Manifold Absolute Pressure, or will I get faulse readings when the valve is open?
Would the brake servo hose be a better source?
