michaelgeorge
hi folks does anyone know if unichip do a chip for the vectra sri 150 z22se engine cheers
Interesting can I use this for when I boost my z22se engineI am just looking for some Unichip info now for you...
Unichip
Variable valve timing adjustment
Rev limit adjustment
Boost limit & level adjustment
Dual maps for use with different fuel grades & types
Water Injection
Nitrous oxide progressive injection
Bigger/supplementary injector handling
Variable induction control
Launch control for turbo vehicles
Full throttle gear changes
Road speed limiter removal
Speedo conversion for imports
Shift light
Idle speed stabilisation
Unichip is a state of the art piggy-back ECU (Engine Control Unit), designed to optimise the tuning of your petrol car in harmony with your existing ECU. Because every UNICHIP is live tuned to your vehicle, you can be sure you're geting the very most out of your car and any modifications you've made to it.
When a car comes from the factory, it's ECU is set up with very cautious settings from the manufacturer, designed to take account of a wide variation in engineering tolerances, driving conditions and environmental factors. To fine tune each engine off the production line would take more time money and resources than makes sense for the manufacturer.
This is where the UNICHIP comes in. Using the up-to-the-minute tuning facilities of the UNICHIP we can guarantee to give you 100% of your engine's performance 100% of the time. What's more, using our unique modular design UNICHIP can control just about any performance modification you can think of, including Turbochargers, superchargers, nitrous injection, water injection, propane injection, launch control, full throttle gearchanges and much more. Check out the feature list and compare it to any other engine management upgrade - we're sure you'll be impressed
http://www.dastek.co.za/unichip_dealership.htm
