Hi friends, while im waiting for my 312/257 CAMS i would like to test run a new built engine. Old cams failed on bearings (low on oil), but i have here two good 312 s. Did someone tested this setup to start and run the engine?
312 is the casting blank number it doesnt reprosent the profile ground on it
on the z22se you cant put an inlet in the ex postion due to lenth
if its a 2.2 then standard 2.2 cam will work
