Contaminated
So it looks like the chain has slipped! Just thought I'd start a thread and see how long it takes to fix! I have a couple of queries in CAPS below - if anyone has a couple of mins to spare I would really appreciate it.
The wife was driving our 2003 Zafira when apparently it started to rattle and then conked out. RAC man thought starter motor might have failed to disengage - but I suspected the chain. When you tried to turn it over all you got was a click and a beep - which I think is the alarm/imobiliser playing up.
I whipped the cover off and the chain has not broken, but the inlet and exhaust valves look all over the place in terms of position. (ANYONE KNOW WHERE THE CAM LOBES SHOULD BE POINTING RELATIVE TO EACH OTHER?).
I had a mechanic round yesterday who was picking up my kit car to take it away to do some work for me. While he was round he rang his mate who works at a VX dealer and it was this conversation that makes me think the chain has slipped.
The VX dealer said that when they slipped they don't usually damage the valves. I have to say, from reading a load of posts on here I beg to differ! I think it would be daft not to take the head off and check (I'LL SEE IF I CAN FIND A BOLT REMOVAL SEQUENCE FOR THE HEAD REMOVAL, BUT IF ANYONE HAS ANY HEAD REMOVAL TIPS IT WOULD BE APPRECIATED).
Assuming I take the head off, HOW OBVIOUS WILL VALVE AND PISTON DAMAGE BE?
I'm nearly done trying to remove the timing chain cover. Engine mount was a pain but I managed to raise the engine a bit to get to the last bolt. All that's left is the bottom pulley - the bolt on that does just not want to budge.
Last question - given that my cam timing is probably massively all out there is no point locking the cams before I take the chain and head off - IN TERMS OF SORTING THE CAM TIMING OUT WHEN I PUT IT BACK TOGETHER, HOW DO I START FROM SCRATCH?
Thanks in advance for any comments guys. I think I've decided to not get stressed, treat it as a bit of a project and consol myself that in a year the money I've spent will be good news for my kit car. That weighs less than 600kg and runs a 160 bhp zetec. I think a Z22se running weber 45s, a megajolt ECU with Ford coil pack and EDIS and a decent exhaust should be 180 straight off - 200bhp plus if I port, polish and cam it. Anyone got a Z22 in something other than a Vauxhall?
Dan
Dan
