So ive hanged engine clutch csc removed box and refilled with 2.25lts of genuine vx oil and I have a crunch goin in all gears up to 3rd and changing down to 3rd when cold this wasnt there before hand .
Any suggestions chaps ????
As always cheers for any input .
Pedal was a mare t do in the end I put a pipe on pass front brake nipple and tother end on the clutch nipple and filled the csc that way , then it bled up real well got a nice pedal.
