Hi everyone,
I am looking for some advice as I require to change the thermostat on my Vectra SRi 150 because it appears to have stuck open. The gauge eventually starts to move after appx 10 minutes so I am assuming the CT sensor and temperature gauge are working OK.
I rang Vauxhall dealer to enquire how much they would charge for the job and they quoted £115.00 labour plus parts, coolant ..etc (and of course VAT!).
I then thought to myself, 'How difficult is this job?' so I had a look in my Haynes manual with a view to having a crack at it myself and decided to purchase a new thermostat (12622410 - £37.60) and new CT Sensor (15326388 - £10.45) both less discount from Vx dealer.
I have a couple of questions:
Firstly, in the Haynes manual, it says to drain off the coolant release the lower radiator hose - however looking at this it appears very awkward to get to, let alone undo it. What is the best method ?
Secondly, Does the electrical connection to the CTS just simply pull off ?
Thanks
Kevin
Thanks
Kevin
