The signum number 3
having issues with the fan staying on for the life of me i cant source the fault changed the coolant sensor and then thought it was the plug to the ecu but the ecu is reporting the right temps the fan module looked like it had seen better days so swapped it was better but still came on to early and full speed with no shut down after it drop below 85c
only thing left to look at is the a/c pressure switch
also picked up a new fuel filter and drop links its got a bobble on one side
found the issue with the fan the a/c pressure switch was reading 2600kpa so it was putting the fan on to try and get the gas pressure down simply unplugging the sensor stopped the fan
also gave the car its 1st wash engine bay had a 2ns clean also
nice and clean hopefully its dry tomorrow then it can be machine polished
bay clean and starting to dry out
just waiting for the trim dressing to dry off
soon be time to take it all apart again lol
i do like the way you can just pull the case half and rebuild it
6th gear bearing is all the issue is
dirty in there
stripping the shafts down
into the parts wash they go
new bearings on
1st one restacked
2nd one
all three shafts done
case mod :)
finished the box off today
pulled the races out the case after modding a brand new tool to suit :confused:
washed the case out with carb cleaner
new seal and races in
gear packs back in
case all back on had to stop for the rain
went for a test drive and the stick no longer moves when pulling away and the inherent whine has gone
few more jobs to do fix the heat shields at the rear with penny washers they have rotten thru also need to find the clunk at the front
had to do the clutch a few months ago the seal in the box was lecking and contamitaed the clutch plate
all good new seal and csc
had an issue with the high pressure pump again it seems the main bearing for the input shaft had come out of the case just enough to stop the internal pistons being pushed leading to 360kpa and not 5000+kpa
green stud lock and a 10ton press soon fixed it all back o 100% again
as i dont use this car anymore and its to good to sell ie given it to my dad as a run around hes happy with that lol
