I dreaded mine back in august and it sailed through it was really chuffed. U be fine . I was worried about emissions as u can't check that till the big day
I'm taking Amy's Fiat 500 in on Thursday. I know we are at least going to get an advisory on the exhaust, as it was blowing the last time we had it MOTd, and I've not had it fixed yet
I did know about the discs
The pipe I missed
Looking at getting a set of drilled discs for each corner
Not sure on the pads yet
But defo want the braided flexis
I will then replace the solid pipe on the rear beam
