P
Polished Bliss
Guest
For the benefit of anyone with hearing difficulties, here is the audio transcript in full; if there is anything else we can do to make our videos more accessible, please don’t hesitate to let us know…
“Hello, this is Rich at Polished Bliss, and in this video I’m going to tell you a little bit about Swissvax Leather Cleaner, and in particular why it’s become one of our favourite products for cleaning modern leather upholstery.
Swissvax Leather Cleaner is a gentle yet highly effective liquid cleaner enriched with biodegradable active ingredients and glycerine. Its mild formula can safely be used to remove everyday dirt and grime on a regular basis with no risk of degrading modern leather surfaces. Indeed, Swissvax Leather Cleaner should always be used to clean even lightly soiled leather ahead of regular conditioning with Swissvax Leather Milk, so as to ensure that grime does not have chance to accumulate in your leather’s surface pores.
For best results, Swissvax Leather Cleaner should be sprayed directly onto leather surfaces to be treated and then worked in thoroughly in a circular motion using a Swissvax Cleaning Brush. This action will produce a slightly foamy looking lather, which may progressively discolour as soiling is gently released. To finish off, all traces of this lather should be mopped up and gently wiped away using a suitable microfibre towel, and the leather then left to dry fully before a conditioning coat of Swissvax Leather Milk is applied.
So, why do we rate Swissvax Leather Cleaner so highly? Firstly, because it tackles everyday dirt and grime with ease, and this includes dye transfer from jeans. Secondly, because it’s thin, easy clean up formula makes it fast and efficient to work with, which is equally beneficial to enthusiasts and professionals alike.
If you have any questions, please don’t hesitate to get in touch using the details provided on the contact us page of our website.”
Finally, if the above video has whet your appetite, you can find out more here – Swissvax Leather Cleaner | Ultra Safe Liquid Leather Cleaner
Continue reading...
Continue reading...
