v6scorpion
So the problem was it was idling rough and making a tick tick tick noise as engine was running, people stated it was timing chain. Anyway ive took apart to get to it and it gets slack when you crank it over by hand between inlet and exhaust sprockets, problem being is i took tensioner out and turned it over again by hand and its knocked out the 4th cams tdc. After ive took off timing chain cover off side and strip to put balance chain on and timing chain on how do i get to get crank and 4th cams at tdc again to correct it all. Massive mistake taking tensioner out and cranking as only seen not to in haynes manual after i had bought it and already done it.
