Heres what I have which parts would be required for your cars ? Also have about 4 complete kits. I noticed some people do not use the alt bracket and tensioner setup or the pump bracket. I have sold a least 10 kits in the UK.
we use the charger,inlet manifold ,manifold supporting bracket ,water pump and bracket,throttle body although im using our 2.2 one as the 2.0 lsj wouldn't fit as the power steering reservoir is in the way ,the tensioner can also be used
