krzysieks1979
Hi All
Since my conversion went Turbo instead as originally wanted SC
i Have Supercharger kit to sell. Kit was imported from US and never have been installed.
So it is unused, although it has been measured once to the engine thus it is unwrapped from original packings.
Kit consists:
-Supercharger with OE pulley
-inlet manifold with endplate and laminovas
-idler pulley
-tensioner
-OE belt
-injectors (as a part of the kit they were able to supply fuel up to ~220hp)
there are bolts and nuts hoses that will go to the buyer but are not on the pictures.
-map sensor that was in original GM kit
-throttle body adapter plate
PS:
I will add as a bonus piece smaller zzp pulley 2,9" with master and bolts
This will go for 1500 pounds plus shipping price that i do not know but i will check
for the interested person. (preferred method paypal)
I do have for additional 60 pounds Cobalt heat exchanger from zzp (may require adjustments to out cars) and bosch water pump
For the conversion YOU will still require some bits and pieces, so i do not sell it as a 100% conversion kit but you will find at least 97% of what you may need i do know that gasket engine to inlet manifold that has been damaged i.e. bend and will have to be purchased separately but this is a 5 quid item. Available from Courtney or Opel/Vauxhall shop
Kit consists:
-idler pulley
-tensioner
-OE belt
PS:
