For Sale Supercharged Ecu and piper cams
dewismotorsport
Vectra b Z22SE Ecu with chip and transponder, mapped by Courtenay sport to 250bhp using the piper cams and CS stage 1 pulley.
Can be sold separately but map will need a re tweek by CS
ECU £250
Piper high lift re profiled cams £100
Prices are excluding postage and packaging.
Parts located in Poole or can take to Coventry at weekends
ai693.photobucket.com_albums_vv292_dewismotorsport_6D45ED45_A7ec7a7901af37d0141844aa166e5c4a3f.jpg
Marty64
Hi Dewis,
What's advantage / difference between piper cams and Comp Cams stage 1/2/3 ?
ZZP S1 is 210/206 @ 1mm and 10.78mm/10.69mm lift, 109 LSA
ZZP S2 is 216/218 @ 1mm and 10.78mm/10.69mm lift, 111 LSA
ZZP S3 is 216/224 @ 1mm and 10.78mm/11.10mm lift, 113 LSA
TY.
dewismotorsport
How many mls are on the cams?
Honestly don't know, I could ask the guy I bought them off to try and find out (y)
Hi Dewis,
TY.
I don't have any specs on the cams I'm afraid :(
piper are stage 1 cams and will work okay with the standard map
stage 2 will require a remap
stage 3 will not work very well on the z22se ecu unless you change to Dutch mapping
