That's the INXX one, but the Raid is virtually the same but uses rectangular section for the cross brace.
As will all G's you need to move the fuse box forward one peg, and get a bit creative with the relay box - I modded the lid to get the clearance, bit others have chopped the bottom off the box to lower it.
you also need to drop the suspension struts to get round the back to hold the nuts whilst you tighten the wing bolts
