Hello Guys, Vectra-c 173k, symptoms misfire at idle only, new IM, new ngk triple ground spark plugs, car drive well at all loads, spark plugs threads on cylinder 3&4 drenched with oil. please watch this video C.T Cyl.4
Looks like the cylinder-4 lost its compression for a second than pick up again what I'm dealing with here a bent valve or a defected hydraulic lifter or maybe the valve guide.
All cylinders have more than 180 psi when tested.
