Sprung a leak
Discussion in 'Engine Queries' started by patricks, August 11, 2017.
  1. Hey guys vocky corsaZ22se got a bad oil leak coming form drivers side of engine its leaking oil onto the right wheel going all the way to the back of the car. Any ideas where it could be coming from. Looks like its predominantly travelling under the car. Im thinking oil seal in the oil pump cover???
    Coolant is clean. Found this out when i took the car to a garage to have the brake fluid changed. They refused to change it unless i cleaned it up underneath first, So what do i need to look for once ive degreased the engine to find out where its coming from.
  2. most likely would be the crank shaft pulley seal. clean it off and run up to see if the oil is coming from here.
    water pump cover plate seal is another possibility or the oil pump/timing cover seal.
  3. Cheers i was thinking crank shaft pulley seal - i didnt replace it when i did my chains two years ago. Water pump seals replaced two years ago. The timing cover seal u mean the gasket??? was in really nice shape when i looked at it last very clean!
    Was soooo insulted by the garage who suggested i take the car to a river......some people have no idea!!! Like to see any other car that makes over 500K virtually trouble free!!
  4. corsaZ22se whats the best way to put the crank seal back in - i dont have the special tool. Is it as simple as pry out the old seal and grease the new one and insert? Or is there a special method that i need to observe??
  5. they go in quite easy (y)
    #5 vocky, August 12, 2017
    • Agree Agree x 1
  6. Wow an easy job on a z22se who would have thought:whistle:. Get the feeling ive really fooked the engine tho by the time i realised it was leaking i had to put in a bit over two litres of oil just to get to the min mark on the dipstick :banghead:, Didnt make any funny noises but ill have to do a comp test as soon as im done
    #6 patricks, August 12, 2017
  7. the first thing to go with low oil is the big end bearings, so if there is no knocking at 2000rpm it should be fine
  8. If you didn't do any hard cornering while oil level was too low, there is a chance that the oil pickup tube was never exposed. Most engines are designed with a generous built-in buffer between min oil level on dipstick and absolute minimum level for safe operation. Some engines will hold oil pressure on just 1 litre of remaining oil (provided you drive very gently to the nearest oil shop :eek: ).
    If the low oil pressure warning never came up ...
    ai.imgbox.com_uFbUfp7G.
    ... that's a good signal (provided low oil pressure warning is reliable on Z22SE engines).
  9. Well thats good to know didnt hear any knocking but didnt take a note of the rpm i just filled it with oil and revved it. And no oil lamp on but then again the only time ive ever seen that is on start up for a second or so not sure if it actually works. Unfortunatley had to drive her home with leaking seal it lost a litre of oil in the-90km trip home and i stopped to top it up half way. Waiting for seal to arrive so not even going to attempt a start up and ill have another listen when its fixed:) Then its pvc mod time lol
  10. most jobs are simple on the z22se :)
    you can use a socket and crank pulley bolt to pull seal in if your doing it in the car. (y)
    • Like Like x 1
  11. Yep doing it with the engine in the car. How do u mean can u elaborate?? Was just going to get two very thin flat blade screwdrivers like in pics and pry it out???
  12. you will need a stronger flat blade than that!
    once pulley is off a decent size flat blade will pop it out.
    then lube up the new seal and with a socket the same od as seal press the new seal into the oil pump housing, making sure it goes in even all the way around.
    • Like Like x 1
  13. Got it! :) That should be easy peasy once ive got passed the bugger of a pulley bolt. BTW my all time fav easy jobs on a z22se is water pump replacement, chain replacement, fuel filter change hate hate hate that job and i also had a lot of fun removing inlet manifold NOT. I think you may be underestimating urself - you are one skilled dude mere mortals like me find z22se a pain to work on.
    • Like Like x 1
  14. not sure what the hardest job is for me?
    changing fuel filter used to be until i got the clip release pliers.
    CV joints are a fiddle to get off.
    bleeding the clutch isn't easy
    but the engines are quite simple to work on.
  15. corsaZ22se which make of pliers do you have for the fuel filter clips? They always seem to break :mad: therefore new ones are required each time.
  16. think they came from Mac Tools? either that or SnapOn? 3 piece set in bargain bin on the van many years ago.
    and it is recommended to use new clips each time which is why new filters come with new clips.
    • Like Like x 1
Matched Content
