Hi guys I'm just wonderig what's the best one to use? There's loads of brands but don't have a clue as never used snow foam before. So any help would be great thanks.
Like Matt said that will be fine, I had some auto brite stuff before as well,I found best results to mix it 50% wash with 50% hot water plus you don't use as much product.
Autobrite's Magifoam is the muts nuts but a bit expensive. Id holds for at least a full half hour so really dissolves crud. This is after half an hour and still doing its stuff.
Thanks for the advice lads I will order that stuff pay day then. I've got a lot of work cut out to get my car sorted for pvs. I'm going to snow foam, wash, clay, polish then wax. And judging by the contaminants in the paint its never been clayed or polished before!
I need to borrow a pressure washer from the in-laws so I can get mine all sorted. Got 4 days week after next to get all the jobs done, as I've got a load of work on the week before PVS
