Hi,
I'm going to replace my chain soon as I get a constant rattle, hesitation and lack of power. I'm putting this down to the chain being stretched and timing out slightly.
Question.. when i take the old chain off, the cams are likely to be in the wrong position. How do I know where to line the cams back up? Can I simply adjust each cam a little to match up with the new sprockets when the new chain is attached?
Also, someone told me the tensioner needs to be oil fed before startup, engine cranked over a few times without firing. Is this true??
Thanks in advance!
Thanks in advance!
